Wrong shaped room !
Discussion in 'Home Cinema Speakers' started by gtfc, Feb 19, 2002.
  1. gtfc
    gtfc
    I've got an oblong room but the TV and seating are opposite each other in one half, leaving the settee right against the wall. The rear surrounds thus end up wall mounted but about 18" from my ear depending on which corner I sit. What would be a better solution for placement ?
    Because of door, fireplace, window, fishtank and other furniture position the TV can't move.
    ________________________
    | {tv} |
    |_____________{ SETTEE }_ |
    Many Thanks
    John
  2. gtfc
    gtfc
    Sorry about the piccy, when posted the picture screwed up.
    The TV and settee are opposite each other on the right hand side.
    Regards
  3. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    How about higher up the wall firing left to right across the settee
