'Wrong' Resolutions being Reported in ifoEdit?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Kevo, Sep 23, 2004.
  1. Kevo
    Kevo
    Aug 23, 2001
    5,398
    Manchester
    +149
    I've recently been converting some DV footage to DVD, all under 1 hour and imported and rendered at the full res 720x576.
    Yet when I open the TS files in ifoEdit it shows the resolution as 356x576!
    If I import these TS files into my editing software they show up as 720x576 in the properties.
    So which is correct? They certailny look full res to me.
    Also in ALL the DVDs I have created ifoEdit shows the menus as being in NTSC 720x480, yet at best they are just static jpegs that I created myself to the the PAL resolutions.
    Using Pan E100 to copy from cam to DVDRAM at XP mode, Ulead Video Studio 8, DVD Workshop2, TMPGenc.
