Wrong Processor
Discussion in 'Desktop & Laptop Computers Forum' started by Whitey1977, Jul 18, 2004.
  1. Whitey1977
    Whitey1977
    Jun 13, 2004
    475
    +43
    I have just upgraded my HTPC with a new motherboard, processor and ram. I ordered a Athlon XP 3200+, which is stated on the box, but the bios and windows XP both state it is a Athlon XP 2500+!
    I have been sent the wrong processor, or have a setting wrong on the motherboard (Gigabyte GA-7N400 Pro2)?
    Whitey
  2. Messiah
    Messiah
    Apr 22, 2002
    7,624
    +338
    Does it not have the processor type/speed printed on the cpu itself?
  3. Whitey1977
    Whitey1977
    Jun 13, 2004
    475
    +43
    They don't usually, just a serial number of some sort.
    I may have to take the pc apart to check but i was hoping that would be the last straw.
  4. jimbob19
    jimbob19
    Sep 5, 2002
    1,543
    Dunstable
    +50
    There is a program that will id the CPU from www.cpuid.com
    hope this helps :)
    It's called cpu-z
  5. Whitey1977
    Whitey1977
    Jun 13, 2004
    475
    +43
    Thanks for that. This program shows the same result as the bios and windows
    Athlon XP2500+
    Looks like an email to dabs.com then
    Thanks for the help
  6. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Is the BIOS on the MB up to date? If it isn't they can misreport the CPU, look on the MB website adn see if a later version is available and what it fixes ;)
    Of course my monies on a DAB's cockup but you never know and it might save you a lot of grief returning it....
  7. The Dude
    The Dude
    May 21, 2004
    6,597
    Beverley, East Yorkshire
    +3,035
    have you checked the multiplier / FSB settingd in the BIOS?
    a 3200 needs to run on a 400(200) FSB, whereas all the other athlons run at 333(166).. if your BIOS doesn't autosense, the FSB will almost certainly be set at 133 or 166 by default.. ??
  8. The Dude
    The Dude
    May 21, 2004
    6,597
    +3,035
    infact, thinking about it..
    166 x 11 = 1826mhz ( XP2500 )
    200 x 11 = 2200mhz ( XP3200 )
    I'd have a look at those BIOS settings before you do anything else ;)
  9. Whitey1977
    Whitey1977
    Jun 13, 2004
    475
    +43
    Thanks for the help.
    I flashed the bios to the lastest version and now I have a Athlon XP 3200+
    I think you where right dude with your FSB calculations
    Thanks again!
    Whitey
