writing speeds
Discussion in 'Blu-ray & DVD Players & Recorders' started by katgem, Aug 10, 2005.
  1. katgem
    katgem
    hi, i'm sure this has been asked before, but i tried doing a search, but didn't know how to phrase it, as it was quite specific. i'm still a newbie to recording media, so forgive me if this is a very obvious point, but i just needed to make sure - i have a panasonic DMR-E55EB/EBL recorder and it has a 1-4x speed function. up till now, i have been using 1-4x speed discs but i've just bought some maxell dvd-r's off play.com, 4.7GB, 120 min etc, which all matches up with my panasonic's requirements, except that they are 1-8x speed. will this knacker up my recorder, or will it be fine? (there's a warning on the side of the disc spindle saying 'Your drive or recorder may be at risk of damage if you use this disc in certain DVD-R/RW drives/recorders that do not conform to using high speed discs'; so i got a bit edgy!) :lease:
  2. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +297
    I use Datawrite Yellow 8x DVD-R in my Panasonic E85 with no problems. It's an earlier model than the one you have.
  3. katgem
    katgem
    yeah, the actual dvd works in the recorder and i've tried recording an hour - works fine. i'm just worried if it'll do any long-term damage. the panasonic model is very good, it's just that you can't choose writing speeds
  4. dicky
    dicky
    Apr 8, 2004
    165
    Cambs
    Hi - your recorder will not get damaged if you use the 1-8x DVD-R's
    Everything should be fine, they will adjust to whatever speed the writer
    can write to.
  5. nialli
    nialli
    Apr 16, 2004
    468
    28
    +25
    I've had problems with x8 discs if high speed dubbing isn't enabled. If it is, shouldn't be a problem. If it isn't, some discs can send the Panny into an elongated self check. I don't think any disc will harm the recorder though, will it?
  6. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    +297
