Writing/labeling DVDRs
Discussion in 'Blu-ray & DVD Players & Recorders' started by bernie_pt, Oct 19, 2005.
  1. bernie_pt
    bernie_pt
    Don't know if this topic have been already answered in the past, but as news on subject of reliability are increasing, I think it's worth to ask.
    Can you give an advice on marking DVDRs with a marker pen? Pens are similar, or are some better than others (marketing blurb excluded)? And labeling with CD/DVD labels (printed or not), is that good? The two methods can affect the DVD reliability (short/long term)?
    Thank you.
  2. GARYFORUMS
    GARYFORUMS
    ditch lables - if they peel your for it
    get some TDK CD pens and use them
    cant comment on the printers onto printable surfaces - so i won't !
  3. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    Yes, labels are asking for trouble. Unless correctly centred they can unbalance the disc and lead to playback problems. As pointed out above, if they peel off inside a hot DVDR then it'll be a disaster.
    Good quality discs with printable surfaces are excellent, if you get a good printer such as the Epson R200.
    Marker pens are the way to go if you do lots of recording: again, as above, choose the ones designed for CDs or else they might rot the polycarbonate.
