Write speed
Discussion in 'Desktop & Laptop Computers Forum' started by seany, Dec 6, 2003.
  1. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    I have a panasonic dvd-ram sw-9581 dvdr drive. Its a max 2x drive. I've heard that some 4xdiscs can damage 2x drives.
    Does anbody know if it's an issue with my panasonic?
    sean
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,353
    Rainham Essex
    +2,441
  3. Garrett
    Garrett
    Apr 21, 2001
    40,739
    2
    167
    The best thief you’ll never see.
    +6,851
    I would have thought the drive will refuse to write on a disk if it is not compatible. I got a Pioneer 106 and it refuses to write on single speed CD-RW the minimum is 2x.
  4. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    Its not an issue in panasonic drives as they will only work at the maximum speed. Some other drives though determine the laser strength from the media inserted and can wind it up higher than the maufacturer intended causing the drive to fail.
    I believe those manufacturers are aware of the problem now and will have released patches to resolve it for older drives, and newer ones will be ok.
    Best bet is to visit the web site of your manufacturer and search for this issue.
  5. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    I heard of this being an issue with Pioneer drives only (where you use the wrong media you could potentially knacker the drive) but as said already new firmware was issued for them.
