Would you upgrade the interconnects/cable on this system?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Fluke, Mar 12, 2006.
  1. Fluke
    Fluke
    Feb 6, 2006
    177
    At the moment I am using a Currys bought (unknown brand) digital interconnect between my Sony RDR GX210 Dvd recorder/player and Nad T741 AV amp, Gale XL189 speaker cable to my Acoustic Evo 3's and Mordaunt Short MSC 20 centre, the rears (cheap n cheerful Eltax) are fed by cheap flat cable but as that cable runs under the carpet I'm not thinking of upgrading that.
    Would I hear any benefit from upgrading the interconnect or Gale speaker cable with the equipment I have?
    I use the Sony for all my viewing and listening (including stereo) by the way.
  2. CJROSS
    CJROSS
    Nov 16, 2000
    5,105
    +343
    No (IMHO).
  3. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    as long as the digital code is read ok does not matter whether the link is an old wire coat hanger,or a diamond encrusted gold cartier cable, it is only a code and not a signal.
    therefore as long as it is an uncorrupted code it will be decoded correctly
  4. shahedz
    shahedz
    Apr 26, 2005
    11,063
    +1,950
    IMHO i wouldnt bother either, i cant tell the difference between optical connectors of differing brands, analouge interconnects yes. optical no
  5. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    No harm in trying a different coax, just to see I suppose.
    Mind you I only notice a slight difference when I plug a 200quid coax in a 110quid dvd player (usually use a 12quid coax).
    But do notice a much bigger difference when its pluged in my usual source for stereo listening, (where it usually lives).
  6. Londondecca
    Londondecca
    Dec 21, 2003
    2,105
    +108
    I would try and get some cable either on loan or maybe on a sale or return basis
  7. Daneel
    Daneel
    Dec 5, 2002
    2,856
    68
    London
    +8
    No.
  8. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,462
    71
    Southsea
    +69
    :thumbsdow Deffo not IMO
  9. Fluke
    Fluke
    Feb 6, 2006
    177
    oh well I think thats settled then :smashin:
