would you trust your wii to this adaptor?
Discussion in 'Nintendo Wii-U & 3DS' started by daven1986, Sep 19, 2007.
  1. daven1986
    daven1986
    Sep 9, 2007
    198
    +17
  2. Tetlee
    Tetlee
    Jan 21, 2004
    20,319
    Taunton
    +4,819
    I would think that one you link to should be fine. If it was me(provided the country you're buying from has the same voltage which presumably it has) I would just cut off the plug and pop a new UK one on.
    Mind you, after saying the above I don't know if you'd have to send the power pack back with the console in case of any faults, in which case perhaps not such a good idea.
  3. daven1986
    daven1986
    Sep 9, 2007
    198
    +17
    thanks, i that case i shall purchase one of the above :)
  4. daven1986
    daven1986
    Sep 9, 2007
    198
    +17
  5. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    Why not just buy a travel adapter so you can change the plug to one that is three pin. You can get them in places like Curry's, Maplins, or any place that sells travel accessories. It would probably be cheaper then buying a another Wii power supply.
  6. daven1986
    daven1986
    Sep 9, 2007
    198
    +17
    i was thinking that, but i dont much like 2 pin plugs - prefer 3 pin as they are more solid.
  7. 27neth
    27neth
    Feb 15, 2007
    3,492
    middlesbrough
    +1,294
    You can buy a adaptor from B&Q for around £2. It is a standard 3 pin english plug which opens up and you fit the 2 pin euro plug inside.
    I have used them a lot, it saves you cutting the euro plugs off and is far better solution than travel plugs.
    John.
  8. 27neth
    27neth
    Feb 15, 2007
    3,492
    middlesbrough
    +1,294
  9. daven1986
    daven1986
    Sep 9, 2007
    198
    +17
    will the wii plug fit ok in them? if so that'd be great :)
    thanks for the suggestions.
  10. 27neth
    27neth
    Feb 15, 2007
    3,492
    middlesbrough
    +1,294
    Which country is the Wii from?
    John.
  11. daven1986
    daven1986
    Sep 9, 2007
    198
    +17
    germany
  12. 27neth
    27neth
    Feb 15, 2007
    3,492
    middlesbrough
    +1,294
    Yes it will work...
    John.
  13. daven1986
    daven1986
    Sep 9, 2007
    198
    +17
    excellent, ordering one now :D thanks
  14. cobbler
    cobbler
    Oct 7, 2006
    344
    28
    Deep inside Devon (the county, not the porn star)
    +55
    My Wii is from Germany, this is what I do ...............
    [​IMG]
    No adapter required.
  15. cgunner
    cgunner
    Why don't you just buy a UK plug from a hardware store and rewire it? It takes 3 minutes and makes you feel like a man. Drink beer while doing it.
