Would You Put Your Amp on Your Sub?
Discussion in 'AV Receivers & Amplifiers' started by gmt steve, Jul 3, 2003.
  1. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    I'm considering an equipment move around, and the big problem is were to put my VSA-AX10. It's big, it runs very hot and the only place to move it would be atop my Kef THX sub. Has anyone else tried a similar setup? It would fit, it would look ok, but I'm worried about vibration. Any thoughts?
  2. jhjerpe
    jhjerpe
    Mar 1, 2003
    701
    2
    28
    North London
    +58
    Hmmm seems like a bad idea to me! Although amps have no moving parts - constant vibration could cause early failures.
  3. nathan_silly
    nathan_silly
    That and having a large magnetic field (from the sub driver) interfering with AV amp.
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    My Denon 1802 is rested on squash ball halves on top of my Paradigm PDR10 (like that or not allowed the amp). I know it's not ideal but doesn't seem to cause any problems...
  5. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    The sub is magnetically shielded, so that paticular aspect shouldn't be a problem Nathan. Keep 'em coming fellas, I really appreciate your opinions.
  6. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
    I'd agree with the vibration comments.
    No matter how much "cushioning" you attempt to use I can't see that the constant rumblings of a sub can do anything but damage to an amplifier's internals in the long run...
    Why not build a small (but strong!) shelf just slightly above the top of your Sub? That way you get the best of both worlds - the right position but no risk of damage?
    K.
  7. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    I have seen what vibration can do to circuit boards I would not recommend it, the shelf sounds like a good idea.
  8. Grimley
    Grimley
    Couldn't do that with my setup (Sony 940 on top of MJ pro 50) the Receiver would probably fall off & damage both! I wouldn't do that myself personally, even if it would be physically possible. I'd be worried about vibrations etc. too.
  9. NicolasB
    NicolasB
    Oct 3, 2002
    6,460
    Emily's Shop
    +898
    Many pieces of AV equipment use capacitors that are microphonic, i.e. their capacitance changes if they're subject to vibration. Putting anything on top of a subwoofer is a Very Bad Idea.
  10. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    No.
  11. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    Thanks for the input gentlemen, I will now try an isolation platform on the floor, at the opposite side of my setup.:smashin:
  12. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Here's another thought then, what about putting the sub on the amp? Surely the amp will be more solid on the floor (in my case) with the amp resting on top. I know not ideal again but I have to compromise with my Mum being a student back from hols over the summer. :nono:
    Furthermore, surely the very presence of a sub (or even speakers) in the room generating these sound waves will have a detrimental effect on the electronics. :confused: :(
