Would you buy the same network kit again?
Discussion in 'Xbox Forums' started by Jordans Norks, Mar 8, 2006.
  1. Jordans Norks
    Jordans Norks
    Feb 16, 2005
    1,700
    48
    +56
    Thought it may be a good idea to post a thread where you could list your router etc and network kit you use for live and home use and whether you would buy the same again...sort of a short review for people thinking of buying.
    Anyway, here goes:-
    I have a netgear DGL 4300 router (gigabit and 108 wireless) and Netgear DGS 1008D gigabit switch and connect to my 360 using a wired connecion. No problems at all..expensive but future proof so over the long run probably will work out cheaper. Wireless seems OK with 108 achievable to my laptop. Yes I would buy the same again as I can not fault it!
  2. Kycleung
    Kycleung
    I've got a Zoom ADSL router, can't fault it. I've been using since Sept 2004 with XBOX LIVE!. Also links up 2 other computers and a laptop. HOWEVER, this is all with wires. If I was buying again I would go wireless and buy the adaptor for the 360 :thumbsup:
  3. wormvortex
    wormvortex
    May 29, 2005
    5,765
    South of Heaven
    +443
    I wouldn't go wireless unless i had a laptop, more to go wrong and have to buy wireless cards for everypc where as every modern pc comes with a ethernet port built it
  4. DarkEntity
    DarkEntity
    Feb 13, 2005
    2,584
    2
    137
    Glasgow
    +606
    Got a main PC with a wired connection to a D-Link DI624.
    Laptop, Ipaq and PSP wireless to same router
    Xbox and Xbo360 also wired to router.
  5. Throttle
    Throttle
    Sep 28, 2004
    1,839
    Leigh
    +109
    Yea id buy same again i've got a us robotics wireless turbo router :confused: its called something like that anyway lol anyhow ive never had no problems with anything wired direct into it or wireless use of laptop and psp :thumbsup:
