Would this work ?
Discussion in 'Desktop & Laptop Computers Forum' started by Trojan, Sep 11, 2003.
  1. Trojan
    Trojan
    Oct 20, 2002
    2,725
    London
    +2,126
    Would it be possible connect my video card to a capture card using s-video and record divx and avi with my dvd burner using windvd recorder software. I looked up the good advice that was given to me in my other thread but was thinking would the above work.
  2. Kramer
    Kramer
    Why would you want to send video from the PC (via very poor quality s-video), only to immediately recapture it again?
    :confused:
    Surely you can just burn the files etc. directly or use conversion software if they're not in the correct format you want?
