Would this work?
H
harrarulz1
I need a new freeview box for my room as my old one has broken. I have a great Samsung HDTV but it unfortunatelly it doesn't have a HDMI output. It has DVI and an audio output but would this work?
Connecting this box,
http://www.argos.co.uk/static/Product/partNumber/5321289.htm
With this cable,
http://www.audiovisualonline.co.uk/...-hdmi-to-dvi-d-interconnect-1.5m/display.html
To this TV?
http://www.argos.co.uk/static/Produ...sma+televisions>FC$Brands=Samsung.Samsung.htm
But what would I use for the audio?
Thanks in advance.
ROYOLD
This Goodmans box is DVB-S which means it is a satellite receiver - not DVB-T (Terrestial freeview).
SamRadford
Do you really want to pay more for the facility to upscale to HD resolution?
H
harrarulz1
I already have the TV and I need a new freeview box anyway so I might I might aswell upgrade.
My point is will it actually work and how will I connect audio?
aekostas
I don't know about HDMI. Re audio, check what the Freeview box outputs and what tv inputs are. Do you also use a receiver or amplifier?
H
harrarulz1
Currently just a reviever. My TV has red/white audio but it also has a blue audio connection as part of the DVI setup.
