would this work
Discussion in 'Subwoofers' started by chrisrand, Sep 7, 2005.
  1. chrisrand
    chrisrand
    Aug 16, 2005
    39
    I am putting together a system at the moment of which the only certain part id a Denon 3805 av receiver. I am intending to couple up with some cantons cd300's and cd200's.
    I have heard some bad reviews about their subwoofer. I have been thinking about the Velodyne SPL800-R , would this be overkill for the system, or is the canton sw ok?
    many thanks
    Chris
  2. Jake James
    Jake James
    I would be very interested in reading these 'reviews' as well.
    Regards
    JJ
