Would this work?
Discussion in 'Plasma TVs Forum' started by Skiny, Sep 22, 2004.
  1. Skiny
    Skiny
    Aug 18, 2004
    287
    19
    Say I had an LCD TV, without a DVI connection, like the Sharp Aquos LC30HV4U. Would I be able to connect it with a DVI cable, to my graphics card, with a DVI to component adapter?
    Assuming this would work, would the quality be degraded with the conversion?
    Any help appreciated,
    Skiny
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    There are 2 flavours of DVI connector, DVI-I and DVI-D. DVI-I is 'intergrated digital and analogue', DVI-D is digital only. If your graphics card is DVI-I it will be able to output VGA as well as DVI, in which case you can connect it to a VGA device with a suitable adapter. I very much doubt it's capable of outputting component video though.
  3. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    3 flavours u forgot DVI-A
  4. Skiny
    Skiny
    Aug 18, 2004
    287
    19
    Is there any way of connecting a DVI-I graphics card, to a non DVI LCD, without much quality loss ?
  5. Skiny
    Skiny
    Aug 18, 2004
    287
    19
    Anyone??
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Yes, with a VGA adapter
