Would this set up be ok.
Discussion in 'Home Cinema Speakers' started by zamwessell, Sep 23, 2003.
  1. zamwessell
    zamwessell
    Jan 2, 2003
    1,196
    +120
    Afer a few posts in the forums and thanks to all your advice i think i have finally chosen what speakers i need to upgade my system.I would just like to know what your thoughts are on this mix:
    The power: Arcam AV8/P7
    The speakers:
    Fronts : B&W Nautilus 803.
    Sides and rears : M&K SS-150 MKII
    Sub: Rel Storm III.
    I do not need to upgrade my centre speaker.
    Thanks.
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    only thing i would suggest is that maybe the sub deserves a greater outlay
    ad
  3. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    I agree 100%
  4. dts_boy
    dts_boy
    Nov 26, 2001
    2,615
    Manchester suburbs...
    +178
    its a horrible system, the Sony davs550 is a much better buy!!!
    no, i would say have a listen to monitor audio gold reference range as thats very good as well.
    summat like gold 20s, centre and grfx surrounds and then the fastbass 212 for low end duties.
    as an alternative to the arcam, might i suggest the parasound halo c2/52 combo, i foudnthis to be more musical and MUCH better at the AV side of things:far more configurable as well.
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    It seems an odd mixture to me with expensive B&W speakers at the front and expensive M&K speakers at the rear. B&W and M&K sound completely different so why don't you go for either one or the other instead of mixing and matching.
    What is the centre that doesn't need upgrading ?
