Would this run on a UK PS3?
Discussion in 'Playstation Forums' started by andrewrunagall, Apr 27, 2007.
  1. andrewrunagall
    andrewrunagall
    Sep 4, 2005
    1,162
    Hadleigh, Essex
    +63
    Would this copy of Dragon's Lair work over here?
    I know it's not the greatest game in the world, but I wouldn't mind seeing it in HD after it's been restored frame by frame and has 5.1 surround sound.
  2. Tony Hoyle
    Tony Hoyle
    Aug 4, 2005
    3,347
    103
    Stockport
    +231
  3. nictry
    nictry
    Apr 28, 2002
    5,846
    Kent
    +652
    Bear in mind though it doesn't matter if you 'lose' on each move it just progresses through to the end anyway so sort of takes the fun away from learning by your mistakes and winning your way through :(
  4. andrewrunagall
    andrewrunagall
    Sep 4, 2005
    1,162
    Hadleigh, Essex
    +63
    Received this on Friday (yes, it does work on Region B players), it's not bad. Quite funny watching the retrospective as the graphics become more clearer.
  5. martind
    martind
    Jul 29, 2005
    1,212
    38
    Birmingham
    +20
    andrewrunagall,
    can you clear up what nictry stated above about the game progressing you onto the next stage even if you make a wrong move?
  6. SoleFever
    SoleFever
    Nov 15, 2005
    1,789
    +55
    It's also available from here:http://www.dvdpacific.com/item.asp?ID=800805. Used them many times in the past and they are really fast with shipping usually, also the cheapest i have found it at about £15.99 including p+p.:thumbsup:
  7. andrewrunagall
    andrewrunagall
    Sep 4, 2005
    1,162
    Hadleigh, Essex
    +63
    It doesn't go thru to the next scene until you've finished the previous one.
    There is a sort of auto-play mode, but that's the director's commentary.
  8. nictry
    nictry
    Apr 28, 2002
    5,846
    Kent
    +652
    That is good to hear, this review here http://bluray.highdefdigest.com/dragonslair.html however suggests the following:
  9. Mad Jack
    Mad Jack
    Oct 7, 2004
    453
    +40
    But the original arcade game wouldn't put you back to the beginning of the scene when you failed. It would randomly choose a scene which you had yet to complete. The only time it would keep repeating the same scene till you got it right would be if that was the only scene you still had to do (usually the dreaded Lizard King for me!)
