Would this be an ok setup?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Oakey, Jul 31, 2003.
  1. Oakey
    Oakey
    Aug 4, 2002
    536
    +6
    Looking to totally replace my HT kit, had pondered on getting the Sony DAV-S888 but I think I'm going to make the leap into seperates. So, any opinions on this potential setup please:
    DVD - Pioneer DV-757ai
    Amp - Marantz SR7300 (barring reported faults, I might risk it)
    Speakers - Kef 2005.2 (5 for £400)
    Sub - unsure
    Would this be a reasonable setup (I don't have a huge room)? Feel free to comment on each system and any suggestions on better equipment (my budget is about £600 for each component). At the moment I'm using a Toshiba 32ZP18 although I'm looking to replace that in the near future with the new 32ZP38. Will also be connecting an Xbox (component to Maratnz maybe?), a PS2 and maybe my Sony LISSA if it's possible.
  2. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    I've never seen or heard them in action but judging by the reviews and reputations you should have an excellent, reasonably high end system.
    I've got a much cheaper, budget system and well happy with it so can't see you going wrong with that lot.
    You may want to think about PAL progressive scan though as I think your telly may be able to take it.
    Cheers,
    Cal.
  3. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Oakey,
    I've been using a Pioneer 757Ai for about six months and have had no problems at all with it unlike some certain other makes. It now plays on my plasma by component (PS on NTSC discs) and the picture is superb. The new models now have PAL PS as standard which would be good for your proposed TV. I'm afraid I have no experience of the amp or speakers you suggest.
    Steve
  4. Oakey
    Oakey
    Aug 4, 2002
    536
    +6
    Hi, I've seen the 757ai available at www.unbeatable.co.uk for £600 although I'm unsure if this is multi-region and it makes no mention of whether it's pal or ntsc PS. I may have to phone them when it comes to time to buy. This would be the TV I plan to get sometime in the future Toshiba PF2 . Does anyone know how much I would get for my current Toshiba 32ZP18 if I was to sell it? It's exactly a year old, I believe I paid £1400 for it this time last year but that was with a JVC S-VHS video as well. Thanks
  5. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,188
    Weardale
    +57
    Hi, I've got the pioneer dv656a and its excellent, I suggest you get a decent sub at some point tho. the sound quality of the Sony isn't supposed to be upto much mind you.
    I've got as yamaha 620 AV amp, and would recommend their AV amps without any hesitation.
  6. Oakey
    Oakey
    Aug 4, 2002
    536
    +6
    The Sony might last me temporarily. Can anyone tell me where the sub plugs into the SR7300? (there's a pic of the rear at www.avland.co.uk). I can't seem to see anything for a sub. Also, what would be a good sub to get? Or would it be worth paying that little extra and buying the Kef 5.1 package?
