welshy
Can someone please tell me if the Hive products I've linked below will work in my house and give me control over multizone heating and hot water?
My setup is:
Potterton Promax SL regular gas boiler in the garage.
Separate hot water tank 1st floor (has it's own thermostat for fixed temperature)
Dual zone & hot water Programmer in Kitchen on ground floor.
Central Heating wired Thermostat in hallway on ground floor.
Central Heating wired Thermostat in main bedroom on 1st floor.
Would the following Hive items be all I need?
My setup is:
Hive Active Heating & Hot Water Thermostat
Order online at Screwfix.com. For use with system and conventional boilers with a separate hot water tank. Control heating and hot water remotely via Android or iOS devices. Geolocation and text control enable heating alerts and send commands to the Hive anytime, anywhere. Functions include...
www.screwfix.com
Hive Active Heating Multizone Thermostat
Order online at Screwfix.com. For households that have more than one heating zone. Designed to work with the Hive Active Heating and the Hive Hub. Once a Hive Active Heating thermostat has been purchased for the first zone, the Hive Active Heating Multizone can be added to control extra heating...
www.screwfix.com
