would the oppo dv971h be any good on a 37" pv500
Discussion in 'Blu-ray & DVD Players & Recorders' started by gunner84, Aug 26, 2005.
  1. gunner84
    gunner84
    Aug 16, 2005
    1,912
    +147
    hi
    has anyone got the oppo dv97 and would it be anygood on a 37" pv500 plasma
    im thinking of getting one but not sure what they are like, i have a really old samsung 709 player which needs replacing now that i have the pv500.
    thanks for any help :)
  2. zAndy1
    zAndy1
    Nov 26, 2002
    19,766
    2
    5
    163
    +6,935
    Well if the resolution of this screen is 1024x720 then it would be an ideal match because it can output 720p via the DVI output. I've got one and the picture is incredible so in terms of getting the most out of your SD DVD collection then I think you'd be hard pushed to beat it for much less than £500. It also plays divx and dvd-audio if they're of any importance to you.
  3. gunner84
    gunner84
    Aug 16, 2005
    1,912
    +147
    yes it is 1024x720
    the pv500 only has a hdmi connection does that matter or does it have to be the same (dvi) as player.
    also can you choose what to upscale to such as 720p or 1080.
    thanks
  4. zAndy1
    zAndy1
    Nov 26, 2002
    19,766
    2
    5
    163
    +6,935
    You can use the supplied DVI cable (if it's long enough!) and use a DVI->HDMI adaptor, that's not a problem at all. And yes you can upscale to 720p or 1080i. I suspect 720p will be the optimum setting for your display though.
    Andy
  5. gunner84
    gunner84
    Aug 16, 2005
    1,912
    +147
    would a dvi to hdmi cable do the same job also.
    thanks
  6. zAndy1
    zAndy1
    Nov 26, 2002
    19,766
    2
    5
    163
    +6,935
    Yeah I would think so
  7. Siamese Cat
    Siamese Cat
    May 31, 2004
    610
    46
    London
    +127
    A dvi to hdmi cable would do the trick and should you buy an Oppo then they give you a choice of whether you want it with a 5 foot dvi to dvi or a 6 foot long dvi to hdmi included with the player at no extra charge.
    Must say I'm really impressed with my Oppo, absolutely terrific through the digital connection. Also mine was multi region out of the box, haven't seen anyone else posting this.
  8. zAndy1
    zAndy1
    Nov 26, 2002
    19,766
    2
    5
    163
    +6,935
    Yeah mine was multi region out of the box as well
  9. MWD
    MWD
    Oct 20, 2004
    148
    16
    S WALES
    Yep mine was MR out of the box too.
