would th ty st07 k fit the 37"pv500 please help
Discussion in 'Plasma TVs' started by gunner84, Aug 25, 2005.
  1. gunner84
    gunner84
    Aug 16, 2005
    1,910
    +146
    hi
    does anyone know if the ty st07 k table top stand would fit the 37"pv500
    there selling them on av sales website .
    thanks
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Don't think so no. It only fits the Panel models.
  3. gunner84
    gunner84
    Aug 16, 2005
    1,910
    +146
    are you sure
    its only the a table top stand
    and my 37"pv500 is a ?panel? (new to plasmas)
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    No it's a TV, and it has other mounting points built into it for that awful floor stand, it needs 2 holes underneath for the 07 stand, there are 2 aluminium spigots that slide in, er well, a bit rudely! and er, screw in place from the back.... If your TV has the girlie bits for this it will fit, you'll have to slide your finger around under the bottom edge and see what you can feel.
  5. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,767
    Norwich
    +644
    It fits the PE50 37", I think they are using the same fitting now rather than having different ones on the Viera like previous ones.
    Edit: actually forget that, the site I found the info on I can't find again, and can't see any more info to say it will fit anywhere else.
