Would itunes allow you to re download songs you forgot to back up?
Discussion in 'iPhone Forum' started by tony kop77, Jan 29, 2009.
Tags:
  1. tony kop77
    tony kop77
    Sep 27, 2002
    6,313
    103
    Northamptonshire
    +304
    A while ago I had to re-install my computer as it was playing up but I forgot to back up the songs I purchased to cd. I thought I would never be able to prove what I purchased so never bothered to contact apple.
    However I just went to my itunes account and noticed there is a purchase history where the songs I forgot to back up are in there so I can prove I purchased them and it is quite a list, I was wondering do you think if I contacted apple they would allow me to re download the songs I lost or would I have to pay for the songs again?
  2. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    20,388
    Inbetween Upgrades !
    +9,558
    You wont have to pay again. You can indeed get them back, i just can't remember how :rolleyes:
  3. dazza1011
    dazza1011
    Jun 21, 2006
    1,875
    116
    Sheffield
    +536
    i think you have to log in to your account then go to purchased songs but as the above poster says i cant remember exactly either:D
    edit: which is what youve done but thought you could dwnload from purchased songs list:confused:
  4. Strobe
    Strobe
    Aug 29, 2003
    2,881
    Southampton
    +181
    I thought once they had been downloaded you could not download them again! That's why you get the iTunes warnings about backing up. There are so many better competing mp3 stores nowadays all at 320 bitrate eg. 7digital, Play, Amazon to name but 3. I've not used Amazon but certainly 7digital and Play allow multiple downloads of the same album before you reach the download limit.
  5. tony kop77
    tony kop77
    Sep 27, 2002
    6,313
    103
    Northamptonshire
    +304
    How easy is it to put them on your ipod if I use play or 7digital?
  6. Strobe
    Strobe
    Aug 29, 2003
    2,881
    Southampton
    +181
    Simple as, just store them on your pc in a suitable folder, and use the add folder to library option in itunes. Sync as normal. Job done! :thumbsup:
