would it make a difference if my screen was slightly too big for throw ration
Discussion in 'Projectors, Screens & Video Processors' started by Sunshinewelly, May 15, 2019 at 10:18 AM.
  1. Sunshinewelly
    Sunshinewelly
    Dec 1, 2005
    5,074
    +462
    I am looking in particular at a react 3 (borderless ) electric screen. There is one near me being sold at a good price and seller says its 104 inches diagonal
    my throw distance is around 101 inches diagonal.
    as the screen is a borderless one in any event i assume the fact its slighly bigger will make no difference?
  2. ShanePJ
    ShanePJ
    Well-known Member AVForums Sponsor
    Jun 20, 2006
    2,707
    Unit 5 The Sidings, Bacup, Lancs, OL13 9RW
    +700
    You usually find that it shows the imperfections in grey/black levels further, but I'm guessing its more with what your comfortable with. It'll be a little bit like when you watch a 2.35:1 movie on a 16:9 screen a similar thing happens although its not all the way round and taking that into account that the borders would stretch all the way round together with extenuating the effects of 2.35:1 at the top and bottom.
    Myself, I don't like it one bit, but others who project onto a wall never seem to complain
  3. mb3195
    mb3195
    Dec 27, 2007
    1,856
    2
    116
    Peterborough
    +1,801
    if its borderless, it MAY not be as noticeable, but this depends on your wall colour.
  4. Abacus
    Abacus
    Jan 19, 2015
    729
    67
    Torbay
    +469
    My personal preference has always been for a bordered screen as it tends to focus the eyes more, however others are happy without, so just try it and see. (You can also create your own border with Tape if it becomes that annoying; just make sure it is thin and matt)
    Bill
  5. Sunshinewelly
    Sunshinewelly
    Dec 1, 2005
    5,074
    +462
    the wall behind is grey so it may work ok
  6. IWC Dopplel
    IWC Dopplel
    Sep 11, 2008
    4,017
    134
    BATH
    +530
    As you have too much white material then a home made boarder sounds ideal
