Would it be safe to put a hoover on the vents?
Discussion in 'Playstation Forums' started by nofear01, Feb 4, 2009.
  1. nofear01
    nofear01
    Apr 21, 2006
    2,154
    3
    +86
    This is a serious question - please no silly replies.
    I am getting so much dust gather on my ps3 lately, and rather than blowing it - I would consider putting the hoover pipe on the vents, what are the chances of this messing it up?
  2. stormy
    stormy
    Dec 16, 2004
    2,984
    +304
    Little to none, I would have thought you would be fine.
  3. Tigerblade
    Tigerblade
    Apr 6, 2004
    7,964
    +590
    Just wipe it away and then use the fan cleaning trick assuming you have a 40/80Gb machine :confused:
    The only thing a hoover will do is scratch it if you run it along...thats all, nothing terrible lol
  4. MeTrek8000
    MeTrek8000
    Mar 27, 2008
    221
    +29
    Yes, i took this option about a week ago instead of using the "fan test" method. :cool:
    But i made the mistake of scratching the top of the PS3 using the dyson nozzle, i should of used the brush attachment. :rolleyes: :rolleyes: :(
  5. DaddyDee
    DaddyDee
    Feb 10, 2003
    1,425
    Waddington
    +89
    How do you do the "fan test" and is it safe to do it it? I'm sure I've heard otherwise. :confused:
  6. Mildoo
    Mildoo
    Oct 17, 2007
    325
    +30
    put an old pair of tights over the nozzle of the hoover, that way you wont scratch anything and you wont hoover up something you shouldnt..
  7. stormy
    stormy
    Dec 16, 2004
    2,984
    +304
    I think there are 2 different "fan tests" people speak of, one is blocking the vents up and forcing the PS3 to overheat and hence run the fans flat out, which is dangerous for the PS3 at best.
    The second seems to be an actual 'feature' of the 40Gb/80Gb PS3. I have done it twice and the PS3 has not blown up (yet). This also forces the fans to run at full pelt but obviously not by overheating the PS3.
    Shut down PS3, switch off the rocker on the back of the PS3, hold the eject button on the front panel and switch the rocker back on while holding the eject button. The PS3 will start up and run the fans at full belt for about 15-30 seconds before shutting down with a flashing red LED.
    Switch the rocker off again, wait a few seconds, switch it back on and boot the PS3 normally.
    No one seems to know the answer to if its official or otherwise but it seems to be a 'feature'.
    Don't hold me responsible if your PS3 melts. :) I seriously don't think it will though. All it seems to do is ramp the fans up to full speed for a few seconds, technically it might lower the life of the fans by a few miliseconds but my guess is if they are made to run that fast they are within spec.
    Make sure the vents are not restricted when you do this if you decide to do it.
  8. cyax
    cyax
    Jul 27, 2008
    40
    11
    +4
    Regular vacuums could generate a buildup of static electricity that could potentially damage the PS3. I wouldn't recommend using one.
  9. stormy
    stormy
    Dec 16, 2004
    2,984
    +304
    I think you would have to have the worst luck in the world if that actually happened in reality.
    My PS3 is always statically charged and attracts a hell of a lot of dust to proove it. Hoovering the vents from the outside could potentially cause damage if the static manage to get to a component. I have stuck my hand in my PC time and time again and even hoovered the inside of it out plenty of times.
    I think that risk is very low from running a hoover on the outside of the vents. It is a risk though. Like crossing the road outside your house.
    The decision of course rests with the OP to weigh up the risk/benefit. :)
  10. Workshed
    Workshed
    Jan 28, 2007
    1,653
    Radstock, Bath
    +146
    This isn't a problem as long as you leave your PS3 plugged in as it would be grounded. Don't you think the air being pushed by the fan, rushing past the plastic and metal that the PS3 is made of would also generate static electricity? ;)
  11. adbrad
    adbrad
    Dec 9, 2008
    618
    leicester
    +54
    I really can't imagine the static being a najor problem, I like the sound of the safe fan cleaning thing. I'm going to try that. It must be an inbuilt feature, the way its done seems like a built in feature.
  12. hodgyboy
    hodgyboy
    Dec 7, 2005
    244
    newbridge,south wales
    +18
    To the Op,my missus been doing it for years:rolleyes:,it's good maintenance tbh.Dust is baaaad,lol
  13. THE_FORCE
    THE_FORCE
    Jan 15, 2007
    7,185
    My own ikkle world.
    +4,454
    I think a hoover with a soft brush attachment is pretty safe - I've been doing it since launch day and no probs here. Your PS3 is human after all, and likes a good sucking as much as the next person.:D
  14. gongatots
    gongatots
    Aug 28, 2005
    902
    premier league burnley!
    +68
    you can`t honestly be worried about hoovering out the air vents?
    i must not love my ps3 enough
    :rotfl:
  15. Robothamster
    Robothamster
    Feb 28, 2008
    21,382
    5
    +14,362
    +1 :smashin:
  16. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
    :rotfl::rotfl::rotfl:
  17. Stinja
    Stinja
    Aug 13, 2003
    12,827
    163
    +4,188
  18. bigkingy
    bigkingy
    Jan 23, 2006
    1,101
    Forest of Dean,England.
    +183
    We have a "Henry" vac and its perfect for ps3 because a) you can turn it to low suction and b) it comes with a soft brush attachment. Does a perfect job!
  19. nofear01
    nofear01
    Apr 21, 2006
    2,154
    3
    +86
    Thanks for your responses guys...
  20. Tokoloshe
    Tokoloshe
    Oct 17, 2006
    234
    +20
    I just bought a new Sony LCD, and reading through the manual I noticed, "Periodic vacuuming of the ventilation openings is recommended to ensure to proper ventilation".
    One to too many I know, but that's what it says. So I reckon you should be OK. :smashin:
  21. blindkiller
    blindkiller
    Apr 14, 2008
    212
    +23
    I hoover mine, just don't use a VAX:rotfl::rotfl::rotfl:
  22. maxh
    maxh
    Mar 19, 2004
    115
    Hertfordshire
    +43
    Just hoovered my 60Gb launch model. No ill effects.
  23. Stinja
    Stinja
    Aug 13, 2003
    12,827
    163
    +4,188
    Or a PDP-11 either! ;)
    (sorry, that's probably a bit old-geeky)
  24. Heroik
    Heroik
    Oct 13, 2008
    1,344
    63
    +141
    I hoover mine all the time lol. I actually have my PS3 facing vertically so gather a lot of dust in the side vents...i don't really know if it is safe but so far my PS3 is running fine lol.
