Thanks Dante, so what would be a good upgrade to take advantage of the dacs in the DVD player?? Also would I benefit from using the dual hdmi outputs if I had one going to the tv and one to the reciver??
Ok thanks, have you any recommendations?? I was looking at the onkyo 809's a while back. Funds are a little low ATM as I went into richer sounds for a hdmi cable and came out with a panasonic wt50! Lets just say the mrs wasn't impressed...
Many thanks Dante, although network capabilitys don't really appeal to me so may there be other models at a lesser price ??
The budget is wide open aslong as the price is right
Yes I see that point, I was just wondering if the recovers you'd mentioned come without the network capabilitys at a lower price![]()
