jamieuk23
Hi I am looking to attach my new PC to my projector. now my grapgics card on my PC has a DVI port and I do have a DVI port on my projector so it would seem obvious to just buy a DVI cable.
only problem is I have all my cables sealed to my wall using trunking and it would be a pain to take it all down just to add a DVI cable.
any way another option I have is to attach my PC to my projector using component using a DVI 2 component adapter >> I sopose like this http://www.tvcables.co.uk/cgi-bin/tvcables/5m-component-dvi.html
Ok so my ? is ! do you think I will still get excellent picture Quality on my screen ??
using it to play games on the big screen and some movies.
thanks for any input !
