Would appreciate some advice please
DCFC79
I'm in desperate need for a TV, current one is playing up and I need to do something about it.
Only issue is I'm limited to where I buy from for 2 reasons, 1 is getting it delivered, I can easily get to Argos and Currys and 2 I can get discount at either retailer, its not ideal but I'm hoping once BF comes I can get a bargain.
I sit pretty much facing the tv so no odd angles and looking at the different screen types it looks like a VA panel would be ok.
Screen size I'm thinking a 43 would be ok as it could go in the bedroom in 3 months time.
Another slight issue is budget, max is £500 but Id rather spend less so I have more to put towards a slightly bigger TV later in the year.
Have seen a Hisense 43A7300FTUK at Currys, would it be suited to my needs ?
Anything else you know of thats better and worth say an extra £100 ?
I know the TV wont be the best, have the best picture, I'm dictated by the budget and where I buy from.
Distance wise Im sat about 8 foot.
