Would anyone lend or hire me a wall chaser if I collect?
Discussion in 'Home Cinema Building DIY' started by AVmaster, Dec 13, 2004.
  1. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    Hi guys
    Would anyone be able to lend or hire me a wall chaser for a couple of weeks. I may be able to collect it as I travel loads for work, and I can leave a deposit if needs be. I won't need it until i've stripped the walls and worked out what's going where and have bought the cable trunking though, but it would be nice to know that I can lay my hands on one when the time comes.
  2. Miniholic
    Miniholic
    Apr 26, 2001
    3,045
    The Shire
    +398
    You can get one for £20 from Machine Mart.
    clicky here!
  3. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    They are only good for going through the top layer of plaster though, I need one that can cut an inch or so wide section out of the brick too.
  4. Capt Morgan
    Capt Morgan
    any good hire shop should have an sds drill that can perform this function
  5. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    How thick a channel can these drills cut though
  6. avanzato
    avanzato
    Jan 21, 2003
    1,879
    Norfolk
    +60
    I used an Armeg channeling chisel, you can get them in various widths and they go in a SDS drill with rotary stop. It's also best if the drill locks the chuck in position too, or the chisel is difficult to control. I cut a channel about 2.5-3cm deep for the conduit I was using but it's extremely messy and will fill the room with dust and bits of brick. I bought a pro SDS drill for £190 and the chisel was £30
    You can also get the cutting disc type which start at £100 for a Ferm one from Screwfix or you hire them from the local hire shop.
  7. Dade
    Dade
    I wouldnt bother with the ones that use cutting discs if I were you, they throw up so much dust. Hire an SDS+ Drill where you can stop the rotation and hire a chisel for it too.
    Thats what I used and I had the three channels I needed done in about an hour.
