Would any buy Kenwood AV? as.....
Discussion in 'AV Receivers & Amplifiers' started by DrPepper, Aug 5, 2002.
  1. DrPepper
    DrPepper
    Oct 2, 2001
    3,396
    Barking Essex
    +276
    ...there is the new Kenwood KRF-X9060D out
    THX Select, THX Surround EX, Dolby Digital EX, Dolby Pro Logic 2
    DTS-ES Discrete 6.1, DTS, DTS Matrix 6.1,DTS Neo-6, Circle Surround II
    I'm tempted to buy this because it is THX select certified.
    ......all for around £400!!!
  2. yonderblue
    yonderblue
    Dec 18, 2001
    302
    Scotland
    +12
    Not sure but spec is impressive, I am stuck which to buy now the Yamaha 630 (£357 Qed-uk.com) or the new Sony 1080 (£359+£12 shipping robertwhyteltd.co.uk) or now this the Kenwood 9060D to go with my new set FS2AV's from empiredirect.
    Also I did a quick hunt around seen the 9060DS (Silver version) for £325 from unbeatable.co.uk.
    Scott
  3. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    What Hifi give favourable reviews, Claiming that this has relaunched Kenwood into and maybe ahead of the competition in this price bracket.
    Had it been out 2 months ago I would have demoed this without doubt!
  4. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    well i would certainly consider it. i'm not sure exactly what equipment you require to run thx, i presume a thx certified speaker system, am i correct?
    and i couldn't budget for that as i'm sure they're expensive.
    can you run thx on traditional equipment used for dd/dts?? obviously not going to reproduce the whole shabang.
    if this is the case it's on my 'to audition' list.
  5. Guest
    Vipen - you can use a THX certified amp no problem. Indeed, you can use a THX certified amp, DVD, or speakers regardless of the rest of your system. THX certification is merely an indication of two things:
    1. Lucasfilm has approved the gear - i.e. it meets their minimum standards for quality in terms of maximum volume without distortion, surround steering and so on...
    2. It contains a THX processor, which you can turn on or off, and which you may or may not like (personally I stay the hell away from THX processing).
    It is possible you might get a 'synergistic' effect when combining THX certified gear into an all-THX system, but I cannot confirm this; you'd need to ask some all-knowing creature like Nic Rhodes to get that info.
  6. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    hey dude, why would you stay away from thx, is this not the current high end or do you just mean thx by kenwood?
  7. Guest
    I myself have a THX processor - what I mean is I don't use the THX processing functions on it. I find they affect the sound in the following ways:
    Positive: A large reduction in 'hiss' and 'hash' around less-than-perfectly recorded dialogue.
    Negative: A decrease in clarity, brightness, and detail - particularly from the centre channel (again, with dialogue).
    Positive: A more diffuse soundfield. By that I mean, it's much harded to pinpoint effects coming from a certain speaker.
    Negative: Music and score loses it's emotional impact.
    As a result, I always leave THX processing off.
    Hope this helps with your decision!
