Would amp on top of sub box be a problem?
Discussion in 'AV Receivers & Amplifiers' started by Jamie C, Mar 22, 2005.
  1. Jamie C
    Jamie C
    Mar 21, 2005
    39
    Would placing an amp on top of my sub box be bad for the amp in any way?
    Sub box in question contains a JL Audio 18w6 so BIG magnet on it.
    Just wondered if it'd cause any harm to either my AV amp or rack mount power amp?
    ta.
  2. lee789
    lee789
    Nov 21, 2003
    444
    +3
    I wouldn't recomend that. Even if the sub is magnetically shielded (not sure that your particular one is) long term the movement/vibration of the sub can't be good for an amp.
