would also be extremely intersted ...
Discussion in 'Plasma TVs Forum' started by MARLEYMAN, May 29, 2003.
  1. MARLEYMAN
    MARLEYMAN
    not to mention grateful if anyone has any connection tips re cables and boxes for the Hitachi 42PD300 with a Sony DVD and SKY + cheers
  2. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    The DVD player can be connected directly to the AV box by RGB scart or component leads dependant on the player. Sky+ connects directly to the other rGB scart. No boxes etc required as one of the joys of the Hitachi is its ease of connection. There is a spare scart for video and the VGA connector as well.
    I have exactly this set-up well Toshiba DVD and the result is excellent.
  3. MARLEYMAN
    MARLEYMAN
    tks for that. I have a DAVs500 which I have just realised doesn't have scart out, but have read other threads saying that picture quality from SVHS is still superb. Don't suppose you have your plasma up on a wall by any chance ?
  4. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    I think the DAV500 only has S-Video output. S-Video is still a high quality output, far superior to composite but down from RGB and Component. Certainly no reason not to opt for S-Video.
    With Sky + you already have S-Video, the DAV also has S-Video. But your screen only has one S-Video input. Therefore, you will have to look at some sort of video switch or an alternative means to connect Sky + to your screen. Converter wise, you're only option is for RGB to Component conversion for the Hitachi screen.
    All the best,
    Dr John Sim.
  5. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    Marleyman
    No I use the supplied tabletop stand but Hitachi list a £100 wall mount.
    There is one S video inut on the Hitachi box. Sky+ has got a RGB scart output which can connect directly to the screen.
    Symanski
    Are you saying that Sky+ would give superior performance via your conversion box RGB to component against a direct RGB scart connection to the Hitachi AV box?
  6. MARLEYMAN
    MARLEYMAN
    tks for this. Would you buy a Svideo to Svideo cable or is there any advantage in buying an SVideo to scart ? I have been grown up, gathered up all my patience and ordered the wall mount from Unicol which will take 4-5 days to arrive. Next weekend I'm actually hoping for bad weather !!!
  7. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    Just checked the unit and have to slightly correct what I said before. The rear s-video socket is an output only,there is an s-video input under the flap at the front. The AV1 scart does accept s-video signal, AV2 and 3 are RGB and composite only. So an S-video to scart lead seems the best option as a front connection is untidy unless you plan to hide the AV box - quite possible as the remote seems to only need to see the screen.
  8. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    Oops. The 42PD3000 has RGB SCARTs, which you can and should connect Sky + to. The 42PMA400 would require a component converter.
    All the best,
    John.
