Would a Wii from thailand work in the UK?
Discussion in 'Nintendo Wii-U & 3DS' started by Anish_R, May 7, 2007.
  1. Anish_R
    Anish_R
    Feb 15, 2007
    191
    28
    +33
    title says it all. going thailand and was wondering if i was able to get a Wii from there wether it would work in the UK and play UK Wii games?
    thanks in advance
  2. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    it will work in NTSC 60hz,so if your tv supports that,then yes.
    youll probably need a stepdown transformer,i think,as well..to convert the power supply,to a uk standard.
    and no,it will not play any uk/PAL games,games are region specific on the wii.
  3. kidgloves
    kidgloves
    Feb 16, 2005
    1,000
    48
    Luton
    +59
    Plus electrical equipment isn't as cheap as you think in Thailand. In some cases it can work out more expensive.
