BasalGanglia
I currently own an Ipod Classic 8th Generation. Been happy with this for years as can store all my mp3 music collection (Currently 110GB) on it. Most of the time just use it with headphones in. But I also connect it to to my AV Receiver (Yamaha RX-V377) using a cable that goes from the bottom (30 pin i think) to an RC Cable split for left and right into the Red and White AUDIO.
I then tried a cable that goes from the bottom of the IPOD to the USB Connection in the front. As expected the sound was much louder and clearer. Connected like this I cannot change the songs on the ipod itself but instead a menu comes up on the screen. I think this may be faulty though as the back and forward did not seem to work and then it suddenly stopped and displayed no device. Not been able to get it to work again.
Anyway there is also an AUX at the front which has a 3.5m Jack input. If I bought a lead that would go from the IPOD to this, would this give a better sound than using the Red and White Analogue AUDIO connections at the back?
So was wondering it was worth buying a new DAP as believe they would have much better DAC for better sound. Would there be much difference when playing though headphones? And if it was connected to the AV Receiver would the DAC be bypassed from the DAP and the one in the AV Receiver be used instead and therefore output the same sound quality? Also looking at a few DAPS the outputs seems to be just a 3.5 jack or is this optimised for a line out to get a better connection?
I would still consider buying a DAP even if the sound was much better using the headphones. I would only need it for music. So coming with Android and features like Blutooth etc would not be needed. So can anyone suggest a budget/mid range one that has excellent sound quality but without all the extra features I don't need. I definitely would not want to spent more than £300 unless I can get a good one second hand. And can you tell me how to connect it to the AV Receiver for the best sound quality?
