Worth upgrading from progressive dvd player to 720p player?
Discussion in 'Blu-ray & DVD Players & Recorders' started by m1ket, Sep 25, 2005.
  1. m1ket
    m1ket
    Aug 24, 2005
    3,692
    UK
    +333
    I currently have a dvd player which i bought from a supermarket for £40 to my amazement it has component outputs which can provide a 5XXp outout to my new 26" hdtv the dvds look pretty good like this but i cant help thinking that the output from my dvd player may be be low quality due to the price...
    So i am concidering getting a player that can output 720p directly (with built in upscaling in theh dvd player), so my question is ....
    Is there a big difference between the progressive outout from a standard dvd player and the scaled up 720p dvd players out there?
    Mike
  2. Shakey_Jake33
    Shakey_Jake33
    I personally feel that it's worth getting a 720p player for the DVI output alone.
    As for whether 720p improves image... you will get different views on this, as ultimately your set upscales everything to it's own resolution anyway... but the visual improvement using 720p on my Oppo player compared to 480p is very noticable.
  3. richard plumb
    richard plumb
    Jan 27, 2002
    14,346
    Windsor
    +1,028
    I asked a similar question a while back and the general response was 'don't bother' - although I had a more expensive progressive player.
    Basically, you either scale up to 720p using a new DVD player, or the TV does it for you. If you have a good TV, its quite likely it'll do just as good a job, or might even do a better job, than a scaling player.
    IMO these current players are just a stopgap - I'd save the precious HDMI/DVI socket for your Sky HD or bluray player for proper HD.
  4. m1ket
    m1ket
    Aug 24, 2005
    3,692
    UK
    +333
    ok thanks for that i may as well wait any idea when the HD players are released (i know the ps3 will have one in it) as i think the ps3 will be realesed over here late next year... will the actual stand alone players be before then?
