Worth changing an AE500 for an AE700?
Discussion in 'Projectors, Screens & Video Processors' started by (GTV)Chris, Jun 25, 2005.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Always wanting to fiddle and change things.
    Will there be a vast difference between my AE500 panny and an AE700?
    Chris
  2. DEANO-B
    DEANO-B
    Oct 15, 2004
    516
    Leeds
    My mate had a 500 and upgraded to the 700 and thinks its money well spent. The main difference is the black levels on the 700 are far better. If this is a main concern to you then it may be worth upgrading, although I would suggest you make sure you get a model with the latest firmare on (1.07). The other option would be to wait for the next model (900??) to be released, but the problem is as there are no release dates for this you may be waiting a long time. Saying that though you can now pick up a 700 for less than £1000 which i'm sure will be a lot cheaper than the next model out.
  3. pjh777
    pjh777
    Sorry to hijack the thread but I'm in the same position.
    I have a ceiling mounted ae500, anyone whos upgraded - Will the 700 fit on the existing mounting plate and is the height/throw distance the same? Ie will I just be able to unbolt the 500 and replace it with a 700?
    thanks
    Paul.
  4. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Yep I`m in the same boat as well. It looks like they have the same throw using the calculator on Prejector central.
  5. Goof
    Goof
    Oct 14, 2002
    794
    Scotland
    +3
    I believe all the panny's have the same mounting holes.
  6. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    4,995
    Lockerbie, Scotland
    +907
    Although the mounting holes are in the same place the lens throws differently. So you can use your exisiting mount but the projected image will not appear in the same place.
    Regards
    KH
  7. pjh777
    pjh777
    So can the AE700 get back the original AE500 picture using its lens adjustment?
    My screen is fairly fixed and I was hoping for a simple unbolt and replace type operation.
  8. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    I was under the impression they have a very similar if not identical throw distance :confused:
  9. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Changed my 500 for a 700 and it swapped straight over, same mount same screen size same everything , did have to use a bit of lens shift as the centre position was a bit to the left compared with the 500 but nothing drastic. Well worth the updgrade as I was never that happy with the black levels and vb on my 500, once my mate got his 700 it sealed the deal and I upgraded after only having the 500 for 4 months.
  10. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    What did you sell your AE500 for.
    I do want an upgrade, the 700 is now £999 with pixel check.
    So you say the black levels are even better?
    If the wife finds out about this she will rip a smile in my throat :eek:
    Chris
  11. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    This is a good point. Mine has 1200 hours use in low lamp, its been well looked after. There are a couple of dust blobs but these are easily shifted with a can of air.
    I am thinking of selling for around £375 plus shipping (But rather someone can collect and see it working). This has to be good value for a High Def ready projector with plenty of life in it :confused: THey seem to go for around £600 with low hours (400 or less) on the forum classifieds.
    My main consideration for upgrade is actually the lense shift, I now need to resite my stand due to new seating layout.
  12. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    I sold mine with 0 hours on a brand new bulb (replaced by panasonic) for £850, this was last november when the 700 was still £1350 at most places, couldnt tell you what one would be worth now.
  13. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    How long do we think we will wait until a new panasonic unit (I assume the AE900). Personally I am a little reluctant to make the switch if I know the new unit will be on its way soon.
    Anyone have any inside news? ;)
  14. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    End of this year apparently although any improvements will be minimal by all accounts.
