Worth buying an expensive optical cable?
Discussion in 'Cables & Switches' started by JIT, Jul 16, 2004.
  1. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    Looking for two optical cables, one for PS2 and one for Freeview, but is it worth spending any more than £5 on each cable?
    I know this has been discussed before but just asking opinions before i decide to buy.
  2. alpha10
    alpha10
    Jan 22, 2002
    3,200
    Essex
    +193
    No, I wouldn't bother. So long as they look like they are of reasonable quality assembly wise, you'll be fine. :D
  3. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    Never noticed any difference with the ones I've used (cost from free to £20 so no exotic ones), with those components I doubt it's crucial, just go for cheapies.
    Owain
  4. WILD9
    WILD9
    Mar 12, 2003
    157
    Cheltenham
    +6
    Ive tried a couple and never noticed a difference just get as cheap as you can
  5. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    Looks like cheapies then.
  6. noahstout
    noahstout
    What about cable length? Does that matter? Can I get a 50 foot cable with the same image quality?
