Worth Bi-Amping Mission M71 Speakers?
Discussion in 'Home Cinema Speakers' started by Sunday Ironfoot, Jan 27, 2003.
  1. Sunday Ironfoot
    Sunday Ironfoot
    Is it worth Bi-Amping Mission M71i Speakers? The reason I ask is because I've seen a second hand Arcan P75 plus power amp going on ebay for about £150, whereas I ruled out the possibility of Bi-Amping before because I didn't think it was worth £340, but at £150 I might be tempted.
    Do you people think it will make much of a difference with my speakers, I'm considering upgrading to Mission M73's as well, would it make much difference with those, it worth the £150 upgrade?
    My current amp is an Arcam A65 plus designed to go with the P75 power amp which is another plus.
    Cheers for any help!
  2. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    Frankly,I dont think you'll notice a great deal of difference,since whilst the Mission is a very good speaker at the price level,it's probably asking a bit much to expect that level of detail recovery from it......it doesn't however mean that the P75 isn't worth having at that price,and using the setup as planned until you can upgrade the speakers and really reap the benefits.
