Worries
Discussion in 'Home Cinema Speakers' started by fabio1605, Jul 7, 2004.
  1. fabio1605
    fabio1605
    When ive got me amp on nice and above half... speakers move back n forth a bit... fair enoguth but if it goes to about 3/4 they move a lot more... just a bit worried ... should i not be pushin that much or is them moving A LOT just part of how it all works
  2. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    749
    16
    Derbyshire
    Its all irrelevant really how far the volume control is set.
    What determines how loud a speaker is at a fixed volume is speaker sensitivity, impedance, enclosure type and a whole host of other factors.
    Distortion is what you should be concerned about and then running high volumes levels for extended periods, which will shorten the life of the speaker.
