Working load of?
A
AV nutter
Coatch bolts in going out tommorow to get a bracket made up using 5mm steel plate bent to my design then comming off of that a pole bent at 30degress to allow the drop for my pj welded to another plate 30inches long by 20inches wide i will have two picese of unitstru welded to allow for the pj move forward and backwards i plan to use 6 coatch bolts on this unit i think i work out the working load right but not quite sure any help more than greatful.mike
A
AV nutter
Barcoing Mad said:
Sounds superbly over-engineered.
So it might be but im only a novice can suggest better for my sloping ceiling over to you waiting.mike
