The terms/adjectives used to describe/rate sound/music reproduction are a potential subjective quagmire. In the Ontario VQA wine industry, there is a specific list of terms vintners are allowed to use to describe their products. Not so in the audio industry... Does "crisp highs" or "tight bass" mean the same thing to all listeners of all genres? Doubtful.
I can radically change the character of the bass in my room by merely moving the subwoofer or turning the sub volume up or down. In my own system, volume-compensated digital-sourced with the bass optimized to showcase Supertramp will literally shake the floor when playing You Should Se Me In A Crown or I'm Only Human with the exact same settings. Are the speakers/sub at fault? Probably not. One aspect of the Circle of Confusion.
Maybe one day some eager-beaver audiophile-statistician will analyze reviewers' use of specific terms to tease out whether it is the reviewers' rooms, systems, ears/brains driving the descriptions or the speakers/gear actually exhibiting the characteristics. Toole did some of this for particular recording control rooms and the engineers who worked in them. I know my perception of my own system varies noticeably with humidity (it swings from very humid summers to very dry winters here). Few hifi enthusiasts have separate listening rooms tightly controlled for temperature/humidity, so no matter what the reviewer says, the ambient conditions in a listener's room will be different enough to change those subtle, nuanced responses reviewers focus on. And that is just one potential set of room conditions, and not the most influential, in a VERY long list.
A tour through even the most popular/prolific reviewer sites will show many different ratings/descriptors for the same speakers... one may assume modern speakers worth the effort of reviewing are manufactured to reasonably close tolerances (yes, higher price should give tighter tolerances) so what is the difference in the reviews? Toole put a stake through the subjective ratings zombie by analyzing the Consumer Reports reviews vs. his own testing.
As Derek S-H states, adding in the subjective rating of the speakers/system's ability to handle the various genre/artist style/content of the music to this mess and it gets silly fast. We listen to nearly all music except rap and opera. I also draw the line at country music where if you play it backwards, your girlfriend comes home, your lost dog is found and your stolen pickup truck is returned undamaged.
I guess my system genre-handling would mirror my own skill-set, jack-of-all-trades master of none. It works for me, at a price I could afford.
Toole gives this advice: Look for L-R speakers that give the flattest/widest-dispersion anechoic plots in your price range. Bass response is mostly shaped by the room/positioning, assuming again that the anechoic sub/woofer response is as flat as possible in your price range. Careful positioning and appropriate EQ correction can help get the best performance out of any set of speakers.
