Worcester Boiler Error Codes - Anyone Know Them
Discussion in 'General Chat' started by nheather, Dec 12, 2017.
Tags:
Thread Status:
Not open for further replies.
  1. nheather
    nheather
    Oct 6, 2004
    19,924
    167
    Horsham, West Sussex
    +10,235
    Does anyone know the error codes for the Worcester Greenstar 24 Ri boiler.
    Mine keeps crashing - the only indicator is a blue light - this flashes a pattern which I understand indicates the specific problem.
    Tried googling but all the hits I have found are for models with a alphanumeric display.
    Cheers,
    Nigel
  2. Cocksure
    Cocksure
    Oct 27, 2005
    4,461
    Manchester
    +1,554
    Google the installation manual, somewhere in there you will find an explanation of what the code means.
    The Worcester Bosch website is the 1st place to look in the installer section
    Edit
    Might also be in the user's manual, how much detail it will give though is another matter
    Best way to search is with the boiler gas council number (g c no.) Will be on a data plate/sticker somewhere on the boiler
  3. spinaltap
    spinaltap
    Oct 3, 2004
    2,808
    Birmingham
    +1,393
    This identical problem happened to me earlier today on my 24Ri. No heating or hot water.
    I had slow Blue flashing light. Any attempt to restart boiler resulted in temporary pump engagement before shutting down completely.
    From previous experience, the problem lies with a clogged/frozen condensate pipe.
    Solution: use hairdryer, or warm/hot (but not boiling) water on external condensate pipe. Then, rotate boiler knob to ‘reset’, and then back to its previous setting (you might also switch boiler mains on and off prior to this).
    It took an hour or so before my boiler came back to life today. You might experience a ‘gurgling’ sound as the boiler restarts.
  4. nheather
    nheather
    Oct 6, 2004
    19,924
    167
    +10,235
    Mine is different to that. If I turn the number to 'reset in a fuel seconds the boiler starts and the blue light goes solid.
    It then runs for normal for anything between a couple of hours to a couple of days.
    Next time it crashes I will note the flash pattern but without a list of what they mean it will be moot.
    Cheers,
    Nigel
  5. rousetafarian
    rousetafarian
    Aug 17, 2007
    23,811
    2
    NW
    +15,835
    Nigel
    Please use the very popular central heating and plumbing rather than starting a new thread.
    Thanks in advance.
Thread Status:
