Question Woofer shaking. FLAC vs mp3
Discussion in 'Hi-Fi Stereo Speakers' started by DECKARD71, Sep 8, 2017.
  1. DECKARD71
    DECKARD71
    Sep 7, 2007
    632
    43
    +119
    Hello
    Today I was listening to music, specifically So What (Miles Davis) and I realized the 2 low woofers from my left speaker were vibrating quite noticeably. I was playing FLAC 24/96 through Plex. Just for curiosity I switched to Spotify, played the same song, same album release, same volume, and the woofers did not vibrate, nothing
    I have no idea why, but I am curious... are FLAC, or any hi-res format, putting more SPL in the system??
  2. larkone
    larkone
    Apr 21, 2006
    4,366
    134
    North Essex
    +1,239
    More than likely a wider dynamic range with the FLAC files. Spotify is not MP3, but OGG Vorbis and between 90-320kbps depending on your account and settings, so not a patch on a well ripped FLAC file. Lossy vs Lossless
  3. MIKEVO
    MIKEVO
    Jul 26, 2012
    1,893
    116
    +668
    Different sources may play at different volume levels and it also depends on the mixing of the track.
    The only way to tell is with an SPL meter to balance the volume accurately.
    Resolution affects the higher frequencies more than bass.
  4. DECKARD71
    DECKARD71
    Sep 7, 2007
    632
    43
    +119
    I have Spotify premium, streaming at 320kbps.
    I have to reckon that I do not notice much difference in SQ between Spotify and FLAC... but the woofers clearly notice the difference
    Thanks for the info, I did not know the dynamic range could physically impact on the speakers
  5. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,321
    +1,278
    Am assuming the sound wasn't distorting just that you could visibly see the woofers moving more with FLAC ?
    How loud where you listening ?
    I would still have expected them to move with Spotify otherwise I would expect an audible difference ?
  6. larkone
    larkone
    Apr 21, 2006
    4,366
    134
    North Essex
    +1,239
    • Like Like x 1
    • Useful Useful x 1
    • List
  7. Deleted member 781788
    The FLAC version may have more low frequency, as FLAC is a bit-perfect compression codec.
    Spotify may use subsonic/supersonic filters before a lossy compression, in order to allocate more bits for the all important midrange, sacrificing some extreme frequencies.
    Your system is capable of reproducing these low frequencies, and therefore the bass drive movements.
  8. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,321
    +1,278
    But you should hear\feel the difference in that case then.
  9. DECKARD71
    DECKARD71
    Sep 7, 2007
    632
    43
    +119
    Yep, for me the sound was the same, no more bass
  10. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,321
    +1,278
    But you hear difference between two speakers cables ? We humans are strange ;)
  11. DECKARD71
    DECKARD71
    Sep 7, 2007
    632
    43
    +119
    I do
