wood floors ok?
Discussion in 'Home Cinema Speakers' started by IGADHIA, Jun 6, 2002.
  1. IGADHIA
    IGADHIA
    hey guys...
    wondering what kind of floor is best for these things?
    gonna get some kef eggs or maye vm1's...wondering if a wood floor is ok? or carpet?
    thanks
  2. garmtz
    garmtz
    Mar 27, 2002
    305
    Netherlands
    Choose whichever one you like best... :)
    A HT-room should be damped well, but not overdamped. Both a wooden floor with a rug would be fine, as well as carpet.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Agree with garmtz; and if there is no carpet in the area where the speakers are standing and they need to be on spikes use a marble slab underneath to prevent the floor from getting damaged.
  4. IGADHIA
    IGADHIA
    this will not be a problem was I am planning on vm1's or eggs. so they will be wall mounted.
    thanks anyway!
  5. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,621
    7
    167
    Birmingham, UK
    +10,500
    My general understanding is that wood floors could vibrate with the sound creating unwanted noise.
    The best floor is concrete with a carpet on.
  6. uncle eric
    uncle eric
    Stuart,
    Thats not the case. Not much time to expand so I'll try and cover this later.
    Regards
    Eric
  7. garmtz
    garmtz
    Mar 27, 2002
    305
    Netherlands
    I think a wooden floor sounds more "alive" than a concrete one, which can sometimes be beneficial. Also, with LFE, it gives you those nice vibrations/kicks... :)
