Quantcast
Wont auto log on to live
ArcAngel78
Or some reason my Xbox won't log on to live automatically any more. It thinks it doesn't have an Internet connection until I run a network test - which is then fine. I an then log into my profile.
Is really annoying having to do this network test each time I turn on the xbox. Network is hardwired over cat6. Anyone any ideas?
raveydaveyuk
Ive been having the same problem for about 3 months and it was driving me crazy! I eventually moved the IP address of the xbox into the DMZ on the router and its fine now!
ArcAngel78
Thanks will try that
