Wolf Spider
Discussion in 'Photography Forums' started by allie_c, Sep 5, 2007.
  1. allie_c
    allie_c
    Jun 10, 2007
    318
    28
    +35
    A wlf spider at 1.5x life size. MPE-65 and 30D.
    [​IMG]
    [​IMG]
    MOD COMMENT
    Allie for future reference try and keep file sizes to 200kb for embedding thanks
  2. jomike
    jomike
    Nov 5, 2005
    2,161
    116
    Frimley, Surrey
    +527
    Another excellent capture Allie :thumbsup: You are really getting the hang of the MP-E 65 it seems.
    Were these stacked?
    Mike
  3. T0MAT01
    T0MAT01
    Dec 25, 2004
    2,383
    113
    Devon, Sussex or somewhere inbetween.
    +552
    More great shots Allie!
    These are spot on, nice and sharp with a good depth of field. :thumbsup:
  4. stevegreen
    stevegreen
    May 14, 2001
    8,746
    in my Hymer
    +921
    Can you explain this? Me no understand :confused:
  5. GaryK26
    GaryK26
    Mar 8, 2006
    334
    28
    Aylesbury, Bucks
    +57
    Hi Steve,
    jomike was referring to a technique that allie_c has used in the past to overcome the extremely narrow DoF issues that you get when working in macro.
    The basic idea is that a number of images are taken, each focusing on different areas of the subject. These images ae then combined (stacked) using some software which then gives the final image a much greater DoF.
    Have a search through allie_c's posts and you'll see what its all about.
    Regards
    Gary
  6. stevegreen
    stevegreen
    May 14, 2001
    8,746
    in my Hymer
    +921
    Ah, I see. Does that not cause problems with the subject moving?
    It's not something I had heard of referred to in that way.
  7. jomike
    jomike
    Nov 5, 2005
    2,161
    116
    Frimley, Surrey
    +527
    Yes, you do have to have a still subject and camera for this to work. Then you just focus on various parts of the subject and combine the resulting shots
    Here is a bit more on the subject:
    http://www.dgrin.com/showthread.php?t=61316
    Mike
  8. allie_c
    allie_c
    Jun 10, 2007
    318
    28
    +35
    Thanks everyone for viewing and commenting.
    Thanks verymuch Mike, no focus stacking was done on either of these images. It takes a bit of getting used too but it really is an awesome bit of kit.
    Alistair.
  9. Holowlegs
    Holowlegs
    Oct 18, 2005
    4,278
    Ruislip, London
    +1,017
    Hi Allie
    Another great set off shots, great detail.:thumbsup:
    Cheers Holo:smashin::smashin:
