Wohooo Upgrade Time.. suggestion plz..
Discussion in 'Plasma TVs Forum' started by kevshed, Aug 19, 2003.
  1. kevshed
    kevshed
    Oct 30, 2002
    1,246
    48
    bournemouth
    +98
    Hi all...
    Good news is ive got a punter for my rather dated Panny 42" 3 Series...
    Plan is to upgrade to a model that can support the highest resolutions possible.. possibly up to 1080p.... certainly 576p.
    Would like a high resolution panel 1024x1024 minimum...but as usual don't want to spend a small fortune. (sub £3000)... so Pioneer is out)
    Currently im thinking Hitachi 400E after some excellent reviews and the native resolution. Unfortunatly, only place locally that has them is richer sounds, so have seen a pretty apauling demo...but i blame RS not the display at this point.
    Views plz....
    Thx
    Kev
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Panny series 6 or fujitsu HHA
  3. kevshed
    kevshed
    Oct 30, 2002
    1,246
    48
    bournemouth
    +98
    Hmm...
    Well, the Panny 6 is still a 480 line panel... not sure about the fuji.. i dont know that one.
    anyone else... with perhaps a more detailed view ;)
  4. tbrar
    tbrar
    May 31, 2003
    609
    16
    Youve got smallish requirments then ! :D
    1024 x 1024 is going down the ALiS route, Fujitsu and Hitachi (or Sony, Phillips and the rest).
    Personally not a fan, having owned a Hitachi 42PD3000 for a few months, however lots of people are. Its worth looking into ALiS to see if its agreeable to you.
    Where are you located? Nexnix in Horsham (http://www.nexnix.co.uk) will be able to demo the Fuji for you, as well as the other panels that have been mentioned.
    Tony
  5. Vandem
    Vandem
    433MXE is one of the best 40-something inch units out there, although I'd make sure you check your finances to see if you can get a 50inch unit. There are some cheap bargains to be had at the moment.
  6. togad
    togad
    Sep 14, 2002
    291
    +3
    Vandem - care to elaborate a little more? If things go as planned, I'll potentially be getting a 503MXE in about a month's time, so would naturally be interested in where to go for one.
  7. kevshed
    kevshed
    Oct 30, 2002
    1,246
    48
    bournemouth
    +98
    Thanks for the post... Had a look at the Nexnix web site... dem facility looks excellent - so im going to make the effort to go and see them.... bit of a trek - but worth it i think.
    Thanks for the posts!
    Kev
  8. tbrar
    tbrar
    May 31, 2003
    609
    16
    Kevshed
    On the demo front, depends where you are.
    There are a couple of decent AV Dealers who would be able to set you up decent, unbiased and correctly set up (very important I believe) demo's.
    If your in the North then definatly take a trek to Joe Fernand www.tmfsolutions.co.uk , very knowledgable and worth putting a call into in any case.
    Do let us know how you get on.
    Tony
  9. mattsimis
    mattsimis
    Jul 27, 2003
    Ireland
    Of been looking out for 2nd hand or exdemo 42" Plasmas for a while now without much luck. Out interest how much are you selling that one for?
    Matt
