Wobbly screen
Discussion in 'Projectors, Screens & Video Processors' started by Bogeyed, Jan 24, 2005.
  1. Bogeyed
    Bogeyed
    Nov 12, 2004
    79
    Holmfirth,West Yorkshire
    Just installed a new pulldown 77" screen and cant help noticing that on scenes which pan across, the picture appears to have a ripple effect ,like a mini tsunami across the screen about one third of the way in. I assume this is due to the screen not being totally flat when extended and sure enough on inspection ther does appear to be a degree of wrinkling in the affected area. My question is ,how much distortion of the picture is considered acceptable before I should ask for a replacement that may be worse.Is ther any method of 'ironing'out these imperfections or do I just have to spend more to guarantee a flat screen.
  2. mcdonji1
    mcdonji1
    I have seen this on my pull down Panny screen and also thought that it was caused by ripples in screen or fabric. BUT I am sure that I have now seen this on the TV as well.........................maybe my eyes are needing flattened! Or is it some kind of digital artifact?
    Jim
