wobbly panny BD35 - normal?
Discussion in 'Blu-ray & DVD Players & Recorders' started by jwyg, Feb 4, 2009.
  1. jwyg
    jwyg
    Jan 16, 2009
    373
    +8
    i got a panny DB35 from costco a few days ago - put a cd in it just to see what it was like, and when it spins it up, the whole machine wobbles, if you touch it you can feel it vibrating slightly. if you turn the amp down, you can also hear the mechanical noise of the BD player.
    is this normal? i've heard that the higher end models are made a little more robust, is it to avoid this vibration, and is there anything i can do to help?
  2. jwlawler
    jwlawler
    Sep 20, 2007
    555
    28
    +32
    I have not noticed it and I expect that I would. There is another device on top of mine which may damp it but when I first tested it there was not.
    I would return it. Even if it manages to work with a fault like this, I would not trust it to continue doing so.
  3. WGLOVER
    WGLOVER
    Jun 8, 2006
    1,598
    2
    Billinge, Wigan
    +121
    Unless your discs are warped, it should not do this.
  4. teenwolf69
    teenwolf69
    Nov 25, 2008
    37
    11
    Bolton (roaming freely)
    From experience with that panasonic blu ray, that is not normal behaviour :nono:
    You'd be best getting it checked out:smashin:
  5. jwyg
    jwyg
    Jan 16, 2009
    373
    +8
    ok cool, cheers - i'll take it back and see if i can get it replaced :thumbsup:
