WMVHD on Pioneer plasma
Discussion in 'General TV Discussions Forum' started by Eagerbeaver, Jan 4, 2005.
  1. Eagerbeaver
    Eagerbeaver
    I wonder if anyone is using a Pioneer TV (434/5 504/5) for watching WMVHD contnet, if so how good is it.
  2. jaguar
    jaguar
    Nov 17, 2004
    186
    I do.
    Can't get enough of it. Watched those movies over and over again.
    Normally I watch digital cable and with this you do see (all be it few) artifacts, like solarisation and so.
    But when you feed the Pio a real good signal everthing looks perfect.
    So here we are blaming plasmas when we should be blaming the TV input signal.
  3. Eagerbeaver
    Eagerbeaver
    So what equipment are you using to play the files. I take it is a HCPC into the HDMI input?
  4. rimski
    rimski
    I have recently upgraded my PC set up to the following
    AMD Athlon 64 3400+
    1.5gb Ram
    Radeon 9600 Series 256MB Graphics Card
    But only a basic Realtek AC'97 Sound Card
    All played through the
    Iiyama Prolite E481s 19" LCD Monitor DVI Connection and
    Logitech Z680 THX speakers digital optical cable
    I have tried the downloads from www.wmvhd.com and have to say that it is absolutely fantastic.
    The picture is sharper than anything I have ever seen and the sound if just mind blowing.
    My point is that now since seeing that quality I have the great pleasure in having to say that the screen is to small so I need some advice .
    Would it be best to get a Projector/Plasma and keep the LCD Screen for computer work or get a 30"/32" LCD Screen to do the lot. :lesson:
    A bit long winded I know but all advice is greatly taken onboard and debated about heavily at work with the Projector and Plasma Boys
    Cheers :lease:
  5. daredevill
    daredevill
    Jan 8, 2005
    504
    46
    +157
    Get a projector you tight arse ! you know it makes sence !
