WMVHD Hardware Accelaration
Discussion in 'Desktop & Laptop Computers Forum' started by Rambles, Oct 23, 2005.
  1. Rambles
    Rambles
    Jul 14, 2004
    10,526
    167
    UK
    +2,203
    Was looking for info on what the purevideo scaler settings do - and found this by accident.
    It seems to lower cpu usage for me by about 20% when playing back T2 1080 HD film :thumbsup:
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    This is the fix that enabled Nvidias 'pure video' option to actually work as intended. Up until the fix was issued, pure video was little more than a marketing gimmick because there was no way of making it work.
  3. tim k
    tim k
    even though i had everything running fine, i d/l this and when i tried to play a .ts file it says media player cannot open this file in wmp10 and in mce2005. i re-d/l pure video, then the hotfix, and now wmp10 crashes as does mce when i throw a .ts file NOOOOOOOOOO!!! 2 more episodes of series 2 to watch, and this happens. i cant work it out.
    any ideas please?
  4. Rambles
    Rambles
    Jul 14, 2004
    10,526
    167
    UK
    +2,203
    Eeek. Have you got the newest version of the purevideo codec, ends in 77, released last week, it was supposed to improve playback with .ts files.
  5. DaveP
    DaveP
    It seems you have found a way to play this back, would you be good enough to share with me?
    (Or should I use Google ;) )
    Dave
  6. Rambles
    Rambles
    Jul 14, 2004
    10,526
    167
    UK
    +2,203
    It just plays in MCE - copied it to the hard drive, mapped it via My Movies and it just played :confused: I think navigation is a bit flaky but play and stop work ok.
  7. DaveP
    DaveP
    Thanks Lisa, I'll give it a try!
  8. DaveP
    DaveP
    I've installed My Movies but I can't find where to configure the location of my movie files! I've tried the "Edit Collection" but it's double dutch to me! I've also tried the faqs
    Do I have to edit the registry?
    Dave
  9. Rambles
    Rambles
    Jul 14, 2004
    10,526
    167
    UK
    +2,203
    :D Yes, it takes a bit of getting used to... you need to store your films in a particular way - each film having its own folder. If the film is an avi file just put it in one folder - so T2.avi will be in a folder called T2, if you have several avi's name them numerically, so T2_1, T2_2, T2-3 etc and put them all in one folder called T2. If they are ripped DVD's they should be ripped in file mode and stored like this...
    Main folder T2, in that folder an empty folder called AUDIO_TS and another folder called VIDEO_TS in the video-ts folder put all the vobs, ifo's, bup's.
    Now the films are stored correctly, go into edit collection and type in the name of the film, it should automatically download the cover, movie and cast info etc, then when you click to add title, point it to the main 'T2' folder and that should be it. Then go into My Movies and see all your films catalogued, view online trailers and watch them...
  10. TheCrow
    TheCrow
    Jul 16, 2004
    735
    2
    43
    London
    +153
    Surely you can play these files using "My Videos" this works for me with ripped DVDs in folders and most avi and .TS files.
    I don't think My Movies is doing anything clever regards playback it's just a nice database frontend for your movie collection.
  11. DaveP
    DaveP
    The problem I have is that the files are HDWMV and have a .WMV suffix. Strictly speaking it's not a DVD in the usual sense of the word.
    Lisa, are these the files you copied and can play OK? (there are four of them on the 2nd disk of the Extreme Edition)
  12. Rambles
    Rambles
    Jul 14, 2004
    10,526
    167
    UK
    +2,203
    Yes, I can play these back ok within MCE, either via My Movies or My Video's... they should be the same format as the files you can download from Microsoft here . I can also get full 5.1 sound via an spdif cable to my amp, but now I am just showing off :cool:
    So... can you playback these files ok?
  13. DaveP
    DaveP
    Short answer is no!
    I've copied a DVD to disk but it only seems to give me the trailer, cover and info. I still can't point it at the disk that has the files on it. Do I have to put them in the My Mocies folder or can I store them on a drive D for example?
    Thanks for your help (and patience!)
    Dave
  14. TheCrow
    TheCrow
    Jul 16, 2004
    735
    2
    43
    London
    +153
    You need to tell My Movies that your DVD is online as opposed to offline.
    AFAIR it is in the bottom left corner of the edit collection screen
  15. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Well in the next update for media center microsoft will release it's own version of my movies, so hold out ofr tha,t yes it has cover art and movie info to...
  16. Rambles
    Rambles
    Jul 14, 2004
    10,526
    167
    UK
    +2,203
    Can you play it back off the disc? I wonder if there is some copy protection in place that is preventing it getting copied to your hard drive correctly?
  17. DaveP
    DaveP
    They copy ok but, of course, they are protected by CPRM. That's why I am surprised you are able to play them.
    Previous research lead me to believe that I needed a US proxy and had to configure the PC as a US one. Using MC seems too good to be true!
    Thanks MrCrow, those terms confused me as I took online to me online as in on the internet. Offline I took to mean on my PC, the only expalnation for not being "online"!!
    Dave
  18. DaveP
    DaveP
    Right, I've got is sussed now! File Import doesn't really mean import it means tell me where the files are!
    I've pointed it at my folder and it's found the two DVDs I've put there and also the T2 wmv files.
    That's the end of the good news! It can't play the T2 wmv files!
    Thanks to all who contributed and sorry to Lisa for hijacking her thread!
  19. Rambles
    Rambles
    Jul 14, 2004
    10,526
    167
    UK
    +2,203
    Well, I am glad you have made some progress, I don't know why it won't playback the wmv files - is it the copy protection on T2 that is the problem? You could try downloading one of those Microsoft demo's and see if it plays that back ok.....?
  20. DaveP
    DaveP
    It's definitely the CPRM that is the problem. I did get a licence ages ago but it only lasted a week. Once that expires I think you've had it!
    I'm sure it will be fine with the other HD demos/trailers that I have.
    Thanks again for your help.
    Dave
