Demon
Ok, I know this has been asked in one form or another, but I just want to ensure I am going down the right path..
I've built a HTPC to provide a good DVD and HD video source player, and so far its working well, ffdshow/zoomplayer/media portal..
However, I've just borrowed a WMV-HD movie from my brother and run into the problem that I connect to my AV Receiver via SPDIF, and although the material is 6 channel, I only get standard 2 channel PCM over the SPDIF.. I now realise why this is from searching on here..
I've tried AC3 Filter 1.01a, but I can't get this to encode the 6 channels into an AC3/DD Stream... which seems hit and miss for some people.. (tried WMP10 and ZPlayer)
Is there a more reliable software encoder available, or would I be better off buying a cheap terratec 7.1 aureon http://www.microdirect.co.uk/ProductInfo.aspx?ProductID=12299&GroupID=1136
which I believe will do what I need in hardware??
Or do I use a 6 channel analogue connection between PC and AMP (A denon 3802)
I'm sorry if it's a bit noobish, I have searched, but not found enough information for me to understand all the options..
what is everyone else using to get surround sound from WMV9 HD material??
